DASYLab
How do I stop a trigger from occurring more than once
I need to monitor a counter and on the first instance of a trigger condition store the counter value then never let it happen again unitl I restart the test.
Looking for some ideas out there.
Message 1 of 13
(7,729 Views)
1) Use the Start/Stop Trigger
2) Use the Combi Trigger with the stop condition as Never.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 13
(7,727 Views)
Thanks CJ
My bad on my explanation yesterday.
I am monitoring an accelerometer for when it moves.  The change I am looking for to determine movement is a +/- 3% change.  At the FIRST determination of movement I need to store when it happended in "samples", by means of a counter and not let this value be overwritten.
I used a Trigger On Demand block for the 3%, which works for showing when the change has happened.  I have added the Combi trigger like you suggested and this does stop the counter, however it resets to 1 upon stopping so I am not getting the count desired...Any thoughts??
Message 3 of 13
(7,712 Views)
Can you show a screenshot of the data and what you're looking for ?
Message 4 of 13
(7,707 Views)
CJ,
Here is a screenshot of what I am messing with.
Message 5 of 13
(7,705 Views)
Hang on... does .png not work?
Message 6 of 13
(7,703 Views)
jpg
Message 7 of 13
(7,700 Views)
Are you attaching a file or inserting an image?
Insert using this button. This is a PNG.
Message 8 of 13
(7,697 Views)
Message 9 of 13
(7,696 Views)
Okay... can I have the worksheet, too? I need to look at your settings.
Message 10 of 13
(7,694 Views)
