DASYLab
How to Monitor a Machine Pulse
I have what is probably a stupid question, but I have been trying to figure this out with no solution.
What I have is a piece of equipment that provides a pulse every second to show that it is running, I am bringing the pulse into Dasylab and can see it pulsing using a "Status Display".
My question is,  what is a easy way of monitoring the pulse so if it stops for more that a couple of seconds  I can display an error message and shut off other pieces of equipment.
I am using Dasylab ver10 Pro
Thank You
(6,645 Views)
If this is a continuos pulse, you can use the pulse analysis module and measure the frequency of the pulse.  After that you can trigger the output if it is outside a certain window of frequency.
The trigger will go into and action that will send the messaage
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,640 Views)
Or you can use a Sample trigger... if it stays TTL low for too many samples, trigger an error... note that it only outputs a pulse.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,638 Views)
OK,  Thanks will give it a try
(6,634 Views)
