DASYLab
How to connect to an OPC XML DA Server
In order to retrieve data from an automation server i need to connect Dasylab to a OPC XML DA Server.
How is it possible to connect Dasylab to an OPC XML DA Server?
Is only the standard OPC DA supported?
(8,784 Views)
@smon
OPC DA based on DCOM, OPC XML DA based on XML and SOAP. I'm not complete shure but I think the current DASYLab OPC DA Client support - under usage from internal OPC DA API functions - only OPC DA Servers.
MHA
(8,783 Views)
Thank you MHA for your answer.
It seams to be like that, but I find nether in the documentation of Dasylab nor in any webcontent the description of what exactly is supportet by the Dasylab OPC client.
Probably there exists an easy workaround with an OPC DA - OPC XML DA translation tool?
If anyone has worked yet with Dasylab in combination with an OPC XML DA Server I would be very glad to read from you!
(8,778 Views)
@smon
A good idea to think about a software gateway - perhaps is this link
http://www.advosol.com/c-5-xml-da-gateways.aspx
here useful? Perhaps is also a way to test the DASYLab OPC client direct with the XML DA Sample Server from this link http://www.advosol.com/t-SamplesXML.aspx
It's great if you can tell us your results, we have not yet experience to use this way. Which DASYLab Version do you use?
MHa
Message Edited by MHa on 10-16-2009 12:27 AM
(8,770 Views)
Try Matrikon
http://www.matrikonopc.com
They are the OPC experts.
(7,548 Views)
