DASYLab
How to display JPG/BMP image in Dasylab?
In Dasylab Basic, which module does one use to display a JPG or BMP image on the screen?  For example, if I want to display an picture of a cat sometime during the experiment, and then ask the user to press a button, how do I put the picture up on the screen?  Is that possible?
Thanks,  Charlie
(7,266 Views)
Charlie,
We try to monitor all of the DASYLab forums... when posting in the NI Forum, I am obligated to give you the same answer - DASYLab Full allows you to construct up to 200 Layout windows, objects on the layout include bitmaps, controls, and displays. The Message module also allow you to play an AVI file. Both features require the  Action module.
DASYLab Basic only has one Layout Window, nor does it have the Action module, which would control which Layout is displayed.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,265 Views)
