DASYLab
How to generate pulse signal in DAP DLL
I am trying to generate a pulse signal in DASYLab and use this as an analog output through DAP DLL to drive an injector driver.  The signal that I need to generate is simple - a TTL pulse with varying Duty cycles and Frequencies.  The trouble I have is I am currently able to generate this signal as I need it in a normal work sheet.  I have been putting this signal then through to the DAP box and output this through an analog output.  When I connect this signal output to an oscilloscope or my injector driver I only get 1-4 pulses and then the signal output stops although it is still displayed on my Y-t graph in DASYLab.  How can I get this signal to continuously output?
Thanks for the support.
Message 1 of 1
(7,010 Views)
