DASYLab
How to record ethernet NMEA messages with DASYLab 12.0 ?
I would like to record GPS data (NMAE) transmitted by ethernet with DASYLab 12.0. Is-it possible ? Thank you.
Florent
(6,079 Views)
Attached is an example that I did with DASYLab 9 (it will open okay in 12) and a Bluetooth Garmin GPS-10. When connected, the GPS just transmits continually.
It should give you some idea what to do using the ICOMS Input module - the parsing should be almost identical.
An alternative would be to write a GPS module for V13 using the new Script function. I'll think on that -- but, it would be serial too, since I don't have an ethernet connected GPS. If the GPS comes with any kind of libraries (DLL, ActiveX, COM objects), then it would be very easy to write a Script.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,076 Views)
Thank you for your answer and the DASYLab project.
I will try to convert my ethernet connection into a serial port connection RS-232 to test the first solution. I saw some converter on internet. I will come back to you if I have any problem.
(6,061 Views)
