DASYLab
How to use NI USB-6341 with DasyLab 12.0 ?
I would like to use NI USB-6341 with DasyLab 12.0 but I don't find any document related to that. Is it possible ? How to install the NI USB-6341 driver for DasyLab ? Thank you.
Message 1 of 9
(8,013 Views)
Any NI products works with DASYLab trough the MAX in DAQmx.
You will need to create a task in MAX, and then syncronize it in DAYSYLab.
So, if you can create a task with the USB-6341, you should be able to use it in DAYLab.
Make sure that you have installed the DAQmx driver with the DASYLab configurator
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 2 of 9
(8,010 Views)
Hello all !
I accidently try to plug the Ext. level to a high voltage source. The BNC socket burned but the DAQ didn't showed any living signs since then. Does someone know what is the problem ?
Thank you
Message 3 of 9
(7,139 Views)
You should contact the manufacturer to see if it can be repaired.
This is not a DASYLab software issue.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 4 of 9
(7,137 Views)
It sounds like you  need to buy anouther NI board
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 5 of 9
(7,131 Views)
Why , does it seem I burned the whole board
Message 6 of 9
(7,129 Views)
If you cannot see the board with DAQmx, it means that is not working anymore
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 7 of 9
(7,125 Views)
Unless you at least give a shot with restarting the computer and getting the connection back .... (which was successful in deed :manhappy:)
I got it , Thank you anyway
Message 8 of 9
(7,121 Views)
Let me reiterate. This is a software forum for DASYLab.
We are not equipped to diagnose your hardware.
Post in a hardware forum, or contact your local support to see if the board can be repaired.
We will not comment further on this discussion.
Message 9 of 9
(7,119 Views)
