DASYLab
IXXAT CAN driver with action module?
I have to control a servo drive inverter over the CAN bus.
For this I got a USB to CAN converter from IXXAT.
To set (or to read) a parameter I have to send a CAN message only once.
I miss the feature to send a CAN message on an action (as is possible with the RS-232 module).
Is there a chance to get this implemented in the near future?
Or is there another way to do this?
Thanks for any solutions
Peter
(5,812 Views)
I checked with the development team:
There is no action for IXXAT CAN. There are no plans to implement it. I don't know if it will work for him, but he might try to use a relay for output since the CAN send module only sends telegrams if it gets data with changed values.
I hope that this helps. The Relay can be action-controlled.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,805 Views)
