DASYLab
Is it possible to install a usb-6009 in Dasylab?
I need to install a usb-6009 in Dasylab, but Dasylab does not recogise daqmx-devices, or so it seems.
In MAX, I can see that I have traditional NI DAQ installed (7.4.2f3), but the usb devices are listed as daqmx devices.
Is there any way to trick Dasylab into seeing my device?
I usually work in Labview, but now I need to replicate a measurement from  a colleague from Ethiopia and Dasylab is confusing in the beginning.
Would it be easier to use a pci card (we have pci 6220 available)?
max version4.3.0f0
daqmx 8.6.1f0
traditional NI daq 7.4.2f3
dasylab 8.00.00 from 2004, old, I know)
labview 8.2
(8,264 Views)
Accepted by topic author Frank_Mathijs
If you can create an NI-DAQmx task with the device, DASYLab should see it.
There is a download for the NI-DAQmx driver for DASYLab 8.00.04 at www.dasylab.com
http://dasylab.com/content/driver.php?action=filelist&sid=33
We can only provide active support for current versions of DASYLab (V11 and V10), so, there isn't much help available.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,263 Views)
Thanks!
Got it working.
(8,234 Views)
I want to apologize in advance for incomplete technical competence
in the subject, because my amateur level of training.
I also want to apologize to experienced professionals
and especially Mr. CJ_Butler,
for my English machine translation.
I hope you will indulgent  to the Russian citizen,
who is actively interested in operation
of the device NI USB-9006 program DASYLab.
In Russia, unfortunately, very few know
about object-oriented programming in the program DASYLab
(compared with a developed system of training LabVIEV).
Given the popularity of the brand as the NI USB- 6009 ,
I would like to understand in detail the stages of installation,
work in the program DASYLab. ( I use DASYLab 11 , in Windows XP)
My first question is as follows :
why I can not directly see and work with the NI USB- 6009 program DASYLab,
as it comes with a sound card or other devices e.g. , Measurement Computing?
When you open the tab «Hardware Setup» error appears: «No hardware driver loaded»?
Can we do without NI MAX ( task creation and other unnecessary actions (!),
and produce all presets in the program DASYLab (Hardware Settings)?
Indeed, in the program directory has the files as : nddi.dll, niezio.dll?
Why they can not determine the direct control of NI USB- 6009 in DASYLab?
2) Is there a " prime-driver » DASYLab for NI USB- 6009 in DASYLab 11 ? ? ?
Or how else can modify DASYLab driver  (DASYLab NI-DAQmx (?))  for NI USB- 6009 ?
http://dasylab.com/content/driver.php?action=filelist&sid=33 (?)
http://dasylab.com/content/driver.php?action=filelist&sid=575 (?)
Thank You in advance for the opinions expressed.
Igor Viktorovich, from Russia
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/t1.0-9/10302230_395793633896399_2521902383856967762_n.jpg
(7,041 Views)
Hello usserrostov,
Since your question is not related to the previous question in this post I think it would be best to post a New Message in this Forum Category:
http://forums.ni.com/t5/DASYLab/bd-p/50
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,968 Views)
