DASYLab
Kvaser CAN bus
I'm trying to use a kvaser CAN bus card with Dasylab. However I'm not able to use it... Is it possible to use a kvaser card at all in Dasylab? Which module should be used for this? Does anybody know this?
(10,018 Views)
Hello Marcel,
Thank you so much for your post on our discussion forum. The Dasylab section from our forum is to help you with Dasylab in combination with your NI hardware. Please follow the following link for Dasylab in combination with third party hardware.
CAN hardware through the NI CAN driver are supported in Dasylab, please refer to the following KB.
Martijn S
NI Netherlands
(10,011 Views)
Hello Marcel1234,
the current DASYLab Version 11.0.0 supports following CAN interfaces:
- from National Instruments NI-CAN (Frame API, Channel API)
- from Ixxat based on API's VCI-V2 or VCI-V3 (please ask under www.ixxat.de)
- from Vector based on API's CAN Driver Library 4.3 or XL Driver Library (please ask under www.vector-informatik.de)
The Kvaser CAN API is not supported from DASYLab.
MHA (DASYLab Software Development)
(10,007 Views)
hello everyone,
I use LIN KVASER interface for receiving LIN messages, but the problem that I can't receive the entire message, the maximum amount of data that I receive is limited to 4 bytes, can someone help me plz?
(7,763 Views)
National Instruments provides this forum as a courtesy to its customers. However, this is not the primary method for requesting support and assistance with the DASYLab product. NI does not actively sell the DASYLab software, nor does it actively support it.
Where else can you obtain assitance?
We recommend that you contact your reseller first. They know your hardware and software environment, and are most likely to be able to assist you quickly.
You can request help directly from a support engineer by going to the Support section of the www.dasylab.com web page. This is automatically routed based on geography,  to the person best suited to assist you.
If you post a question in this forum, we cannot guarantee a response time.
When requesting support for DASYLab
  • DO NOT post your full DASYLab serial number
  • Please tell us
    • the version of your DASYLab software,
    • the level of your software (Lite, Basic, Full, Pro)
    • the exact DAQ device by manufacturer and model,
    • your operating system and computer,
    • and, if appropriate, a copy of your worksheet.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,735 Views)
