DASYLab
Labjack and Python Drivers
I am looking to see if a device called Labjack can be used with Dasylab.   The interest is to interface with another project and also the ethernet connection on these devices.
I understand the script module supports python scripts and I have a python library provided by Labjack.  Are there any sample script drivers?  I really don't know where to start in terms of what to output in Dasylab and how to setup the channels, blocks, etc.    I read through the Dasylab documentation but it really doesn't get me started.
I really want to be able to use the high speed streaming function, but I would start with a modbus script just to get some understanding of how python works with Dasylab.
Anyone have anything they could offer?
https://labjack.com/support/software/examples/ljm/python
-Z
(10,813 Views)
Hello
Please have a look at out webseite at
https://www.measx.com/en/products/software/dasylab/examples
Here you can find more examples, some of them more extensive, which require at least a Dasylab 2016.
This download contains examples in the following areas:
  • Dialog, user interface
  • Channel types, channel flags
  • Channel relation
  • Channel flag “Short Block”
  • Mathematics
  • Access to global DASYLab variables
Please have a look at it.
Best regards
Stephan
measX GmbH
www.measx.com
(10,770 Views)
Additionally, attached you can find two example scripts for data source modules.
serial_com.py asks a device for data, the device answers. The script parses that answer and outputs the example value.
eigene_zeitbasis.py (sorry, the comments are in German language) shows how to provide a time base, so other DASYLab data source modules can output their data synchronously.
The script uses a "virtual device" to generate data on its own. The interface is a simplified API, that provides some basic functions like Open(), Close(), CheckIfDataIsReady(), GetData().
I think you will be able to get the trick on how to talk to you own devices.
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(10,765 Views)
Stephen,
Thank you for the fast response.  I did not notice the examples section of your website.
I tried to download the script example package but I get a 404 error, file not found.
hw70,
Thanks for the example files, I will review.  Appreciate the help.
-Zac
(10,758 Views)
Accepted by topic author zacman55
@zacman55 wrote:
Stephen,
Should be fixed, now. https://www.measx.com/downloads/DL_Examples/examples_scriptmodule.14.0.0.480.en.dlp
(10,752 Views)
Thanks for the example files.  I was able to get data (from 1 AIN channel for now) from the labjack into dasylab.  I'm really shocked it started working (since I don't know anything about python), but satisfying to stop getting errors.
There are some pains with adding the library to the Dasylab python folder (since I couldn't get the local pip to work, bigger issues with my path since I have python also installed on the windows machine).
If anyone is interested in the code I can share.
(9,836 Views)
LabJack has greatly expanded our support for DASYLab. Since you previously asked about DASYLab I wanted to bring it to your attention in case you missed our recent email newsletter or support updates.
https://labjack.com/support/software/examples/ljm/dasylab
(8,358 Views)
