DASYLab
Layout is freezing
Hello! I have a trouble with my dasylab layout. I am gathering data from 8 chanels with my usb 6009, sampling frequency is 50 Hz. I am visualising this data in an layout and the problem is, that the plot is freezing. The plot is actualising data about every 20 seconds. any ideas what is wrong? (Overall intervall is 1 minute)
This was no problem before i implemented some new features like a signal light from my digital input.
Thanks and have a nice day.
(6,951 Views)
does this happen also when you plot them without the layout?
Which version of DASYLab are you using?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,948 Views)
Accepted by topic author Hilby
Ok sry, for this double post, but after think during writing the last post I got the solution. In the MAX configurator I found the setting "Value to be read" and this was 1000k with 50Hz sampling frequency I got data every 20 seconds.
Bye
(6,947 Views)
Glad you solved your problem
Tom Rizzo
InSyS Corp.
www.insyscorp.com
(6,944 Views)
