DASYLab
Manual module connections
Hallo again!
Is it possible to connect modules manually. I mean the auto-route function is nice as long as you do not want right angles. I want to connect two modules around the corner with parallel connections.
Thanks for every help.
By the way, this forum is great.
Best regards
Hilby
(6,257 Views)
Accepted by topic author Hilby
In the Options menu, turn off the Auto Router.
Please note.... you can manually route the wires - click to change direction, but, if you subsequently move the module, the autorouter kicks in again, and does its thing.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,253 Views)
