DASYLab
Matrix multiplication in dasylab
Can dasylab perform matrix multiplication?
(6,089 Views)
My initial impression is no, DASYLab cannot do that.
Having said ,that, what would the functions look like?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,055 Views)
It would be a 6x6 multiplied by 6x1 matrix.   Basically running a 6dof load and want to see the loads realtime.
(6,052 Views)
The 6x6 would be a constant and the 6x1. Would be 6 voltages from strain gage
(6,050 Views)
maybe the formel interpreter in mathematics can help with that:
6 inputs (x-vector)
6 outputs (y-vector)
36 global variables (A(i,j)-matrix - constant for the module)
for each output the formula would be
y(0)=OUT(0) :
IN(0) * ${VAR_1} + IN(1) * ${VAR_2} ... + IN(5) * ${VAR_6}
y(1):
IN(0) * ${VAR_7} + IN(1) * ${VAR_8} ... + IN(5) * ${VAR_12}
etc...
A(i,j) is stored in global variables row after row A(1,1)->1, A(1,2)->2, (2,1)->7 ...
this is just a suggestion to try - not tried by myself. 🙂
if that does not work, the python module would definitely will do the job.
br,
thomas
(6,041 Views)
THis worked well.  thanks
(6,001 Views)
I have created an example worksheet (works with DASYLab 13, and 2016).
vektor-matrix-produktvektor-matrix-produkt
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(5,935 Views)
