DASYLab
Measurement needs to be restarted to work
We created a dasylab-file to log data from 2 USB-Ports, connected to an almemo (temperatures) and an LMG95e (power, voltage ...). All configuration works fine (RS232-Monitor shows results and good parsing).
But when we start dasylab, open the file and start measurement for the first time,
in the LMG-log an additional "0" appears and the measurement freezes.
So we have to stop and restart the measurement and then everything works fine!
Any idea for this behavior??
(It took us several days to find this "error" and clearly re-produce clearly!)
(6,126 Views)
What version of DASYLab? What Operating System?
Can you send me the worksheet to look at ?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,124 Views)
Dasylab V12 and Windows 7 pro.
Worksheet i can send you this afternoon.
(6,107 Views)
Thank you for sending the worksheet.
You have two RS232 modules configured... the LMG input uses a Start and Stop command. I wonder if the Start command needs to end with a <CR> or \r.
(6,102 Views)
