DASYLab
Multiple Sets of Analog Readings
I am writing a worksheet that collects an analog voltage measurement and converts it to feet per minute (Volts * 400 = fpm) at multiple locations. I am outputting the result to a text file along with the time (in seconds).
So the flow goes like this…
  1. Set up measurement probe at Position 1
  2. Start data collection
  3. Data collects 1 per second for 20 seconds, then stops (pauses)
  4. Move probe to Position 2
  5. Start data collection
  6. Data collects 1 per second for 20 seconds, then stops (pauses)
  7. Repeat 4 – 6 until data has been collected for 12 locations.
  8. Output file is *.csv or *.txt including: Position, Second (1-20), Velocity
Output looks like this:
Measurement time[s],Face Velocity [fpm],
0,64,
1,64,
2,65,
3,63,
4,63,
Here’s where I’m having difficulties…
I need to be able to collect this data for 20 seconds, pause, collect for 20, pause, collect for 20, etc. until I have 12 sets of 20. I know that I can put in a “STOP” control and stop after either 20 seconds or 20 data points and then press collect again to append data to the file. This also works fine. However,  I would like to record which data set is being collected (Let’s call it Location, since I am collecting data from multiple locations) in the output file. Like this:
Location, Measurement time[s],Face Velocity [fpm],
1,0,64,
1,1,64,
1,2,65,
1,3,63,
1,4,63,
1,5,64,
1,6,64,
1,7,65,
1,8,63,
1,9,63,
1,10,64,
1,11,64,
1,12,65,
1,13,63,
1,14,63,
1,15,64,
1,16,64,
1,17,65,
1,18,63,
1,19,63,
2,0,64,
2,1,64,
2,2,65,
2,3,63,
2,4,63,
2,5,64,
2,6,64,
2,7,65,
2,8,63,
2,9,63,
2,10,64,
2,11,64,
2,12,65,
2,13,63,
2,14,63,
2,15,64,
2,16,64,
2,17,65,
2,18,63,
2,19,63,
Etc….
I would appreciate any help I can get.
(3,769 Views)
how do you identify the location?
Maybe a coded switch that you can save to the file? that gives you up to 16 locations, and you can label the buttons ( I would use buttons or a drop down) with words, while saving the number. The numbers don't have to be 0-15 - you can put any value for each switch position.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,756 Views)
