DASYLab
NI USB-9162 and NI 9234 - drivers needed
Hello!
So, I'm trying to create acceleration measurement with DASYLab 9.0 and using NI's USB-9162 carrier and NI 9234 card.
What drivers do I need to install so that Ieverything works correctly?
Thanks in advance.
Teppo
(13,736 Views)
You need to install the DAQmx drivers:
http://digital.ni.com/public.nsf/allkb/9CAF5FF63451EC39862567A6008140FB
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(13,728 Views)
Once you've installed and configured the DAQmx drivers, you'll need to add one or more tasks, using MAX. Configure the settings for each channel, including the sample rate.
When you run DASYLab, you need to verify that the DAQmx tasks were detected, by creating an Input/Output-NI-DAQmx-Analog Input module.
DASYLab is now shipping V11, with the NI Drivers included. For full technical support, we suggest that you update your software to V11.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(13,722 Views)
Thanks for advices.
I go the DAQmx installed and after that I find from 'Devices and interfaces' my NI USB-9234 "Dev 3".
Next probles is that I'm not allowed to click "Properties" for that...so I can't change settings.
-Teppo
(13,707 Views)
You need to go to the Data Neighborhood, and create a Task. Configuration can be done there.
(13,703 Views)
Hello!
I have developed application collecting data from NI usb 9162.But before that i have to run setup of NIDAQ917-1.
Now i don't want to run set of NIDAQ917-1 i am ready to install any needed dll or drivers with my application.
Help me.
(12,363 Views)
I don't know that I understand the question. You need the drivers installed that came with the hardware, including NI-DAQmx and the NI Measurement and Automation World.
DASYLab relies 100% on NI-DAQmx (V8.5 or later, V9.0 or later for Windows 7) for communication with NI hardware. So, you need to "bite the bullet" and install the software that is needed.DASYLab cannot communicate with NI devices without NI software installed.
This device is only supported with NI-DAQmx, and it looks like it first shipped with NI-DAQmx 8.8.
(12,344 Views)
