DASYLab
Output a global variable to RS232 module
Hi
I try to control power supply model for this action i need to send command to the unit
first command is   :ADR01;      its the address of power supply number one.
then i need to send the command      :OUT1;    this command get the power supply on.
can you send me some shoot screen how to send this in rs232
thank you .
Eyal
Message 11 of 14
(3,681 Views)
Manual "5.5.1 Init control", p. 42, #3 says that you need to switch the device manually into remote mode using some button on the the device's front panel.
Place a RS232 input module into the worksheet.
Configure the interface settings.
Go to the RS232 monitor.
Enter :ADR1;:MDL?; then press enter (p.42). The device should answer with some information about its type, name, etc.
Is that working?
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
Message 12 of 14
(3,674 Views)
HI
I do it is not work.
Message 13 of 14
(3,672 Views)
Oh, add \r and/or \n to the string
:ADR1;:MDL?;\r
or
:ADR1;:MDL?;\n
or
:ADR1;:MDL?;\r\n
EDIT:
Ok, the manual says that commands send to the device do not need \r, \n symbols.
Hmm, sometimes the manual uses a colon (p. 48 for example), sometimes a semicolon to present examples.
Perhaps you should try :ADR1::MDL?:   with colons only.
Message 14 of 14
(3,668 Views)
