DASYLab
PCI cards supported by dasylab?
G'day all.
The company im working for is considering purchasing dasylab V9 (latest version) and I am wondering if anyone has a list of PCI boards (in particular vibration) supported by this software. thanks in advance
(8,715 Views)
You'll find the best list at www.dasylab.com -- click on Drivers to view the actively supported drivers, as well as driver series that work, but may not have active ongoing development and support.
There may be other vendors with DASYLab support.
There are many factors associated with purchasing a board for vibration measurement. What are the characteristics of the signal that you need to collect, what sensors will you be using, what signal conditioning / filtering do you need? Some boards come with a direct signal connection for accelerometers, and have filtering and other signal conditioning. Others, you need to purchase a separate signal conditioning solution....
-cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,703 Views)
First of all, Thankyou CJ for the speedy replies.
We are currently looking at the NI PCI-4474 card as we will be interfacing with accelerometers and possibly a couple of proximity sensors. as far as i can see so far this appears to be one of the best options (or the 8 channel version pci-4472) but i am always open to suggestions
thanks to all in advance 🙂
regards
Glenn McDonald
(8,692 Views)
We have a couple of customers using that board quite happily!
We recommend that you use the NI-DAQmx driver, as it provides better support for the unique features of the board.
-cj
(8,681 Views)
Thanks for that advice CJ it is most useful 🙂
(8,671 Views)
