DASYLab
Problem of keeping Timebase setting
Hello guys,
I want to set my timebase of program as DASYLab. But every time I open my program, the timebase will be changed into hardware output or hardware input. And I have to reset it as DASYLab every time.
How can I keep my setting of timebase as DASYLab?
Thanks a lot!
(5,872 Views)
What version of DASYLab are you running? DASYLab 2016 changed how the Timebase settings are managed.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,867 Views)
DASYLab 2016 Basic
(5,857 Views)
Accepted by topic author Hartmut-Germany
"I want to set my timebase of program as DASYLab."
You cannot set a time base for a worksheet ("program"?). You can tell data source modules, like Switch, Slider, or Generator, to output their data based on the properties of the set time base.
Can you provide a screenshot of the setting that changes after loading a worksheet, please?
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(5,820 Views)
Thank you for your reply.
The problem was solved. Because I open the worksheet of DASYLab on a computer without measuring equipments, and save it. Then the time base of all modules will be reset.
(5,808 Views)
