DASYLab
Problem with Export as ASCII
Hi, i have a Problem with Export my Data from DASYLab Version12 to Excel in Time Style.
When i use Timebasse frequence:
It's the Time in Excel like this,, 00:00,0'' instead of ,, 00:00:00''.
How can i fix it in DASYLab?
(I have no Problem when i use S or MS as Timebasse)
(4,808 Views)
Accepted by topic author vahid.mirhosseinian
This is a common problem with how Excel interprets time with fractional seconds.
You have hh:mm:ss.000, but Excel shows you mm:ss.0 -- of course, replace the . (period) with , (comma) if necessary.
You must format the cells (or the entire column) to use a Custom format -- I find that hh:mm:ss.000 works.
Excel does not allow more than 3 decimals on the time format. If your sample rate is greater than 1000 samples/second, you should use the Seconds output, not the Time output.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(4,787 Views)
Thanks alot. I have to do it in Excel.
(4,778 Views)
