DASYLab
Problems sending string over RS232 output
want to control over RS232Output Module (DasyLab7) a relayboard. Therefore i have to send the following string: 7Eh-20h-01h-06h-01h-04h-00h-00h-7Eh (Set) and 7Eh-20h-01h-06h-01h-04h-00h-01h-7Eh (Reset). The Serial Interface Setup is ok and i've enabled "Asynchronous Command" and disabled the "With Control Input", but every time i try sending the string via Output(Format) the board is not responding. I know for sure that the board is functioning ok, because i am using it with a software i wrote in Delphi. Thanks in advance for any help!
Giannis K.
(7,169 Views)
Hi Giannis,
What hardware are you using? Is it a National Instruments DAQ board?
If you are using a DAQ board manufactured by DASYTEC, you can consult DASYTEC Online Support.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(7,150 Views)
