DASYLab
RS232 data format help!
Hello everyone.
I'am new to the use of DASYLab, but I was able to create a worksheet to capture data coming from RS232 port.
The RS232 module has 6 channels (0 to 5)
Chan 0 = Reading number
Chan 1 = PASS1
Chan 2 = PASS 2
Chan 3 = AVG
Chan 4 = AVG LOW
Chan 5 = GRADE
The data coming is in the following order:
<LF><CR>
RDG NO     PASS1     PASS2    AVG<LF><CR><LF>
<CR>
     001           4.17        1.21        2.69<LF><CR>
     002           1.06        1.47        1.26<LF><CR>
     003           0.92        1.70        1.31<LF><CR>
     004           0.81        1.70        1.25<LF><CR>
     005           0.72        1.73        1.22<LF><CR>
     006           0.85        1.51        1.18<LF><CR>
     007           1.10        1.41        1.25<LF><CR>
     008           0.93        1.38        1.15<LF><CR>
     009           1.02        1.31        1.16<LF><CR>
     010           1.03        1.24        1.13<LF><CR>
     011           1.01        1.30        1.15<LF><CR>
     012           1.54        1.50        1.52<LF><CR>
     013           1.56        1.61        1.58<LF><CR>
     014           1.58        1.67        1.62<LF><CR>
     015            ----           ----           ----<LF><CR><LF>
<CR>
LOW AVG      0.00      GRADE 7<LF><CR><LF>
<CR>
LIMIT 1           0.50<LF><CR>
LIMIT 2           0.60<LF><CR>
LIMIT 3           0.70<LF><CR>
I have managed to visualize correctly the "LOW AVG" value and the "GRADE" value.
I have a list module to show in screen the 15 incoming values and then write them to a file. The problem is how to set the data format so all the data is shown into the list module under their respective channel. i.e. Cahnnel 0 shows all the values (001 to 015) and so on for the remaining channels (except for Chan 4 and 5).
Hope you can help me out with this.
Greetings.
(6,152 Views)
I tried a couple of things, but if the header line repeats, it's going to be really hard to parse.
DASYLab is looking for a very regular RS232 string, and this is not regular.
It might be possible to write a script using the DASYLab V13 script feature.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,100 Views)
Thanks CJ.
I'll be waiting for your reply.
Greetengs.
(6,097 Views)
