DASYLab
RS32 Inputmodule, Datarequest in HEX
Hello
i have a little Problem
i must read datas from a Inverter
The Comunication is in RS232, but now i must send a Datarequest in the format is HEX
when i can send following HEX-String i becom the answet of this Parameter
the Code to send is : 02 00 86 31 00 20 85 00 00 00 00 10 (Hex)
now the problem is to insert this string in Dasylab
thanks for help
Thomas
(7,047 Views)
Attach a \x to each byte of the code to tell DASYLab to send hex-data. Remove the blank between the "hex formatted bytes":
\x02\x00\x86\x31...
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(7,037 Views)
Issue solved in measx-forum: http://www.dasylab-forum.de/forum/index.php?showtopic=242
(7,023 Views)
Danke!
Thank you!
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,021 Views)
