DASYLab
Routing Error
I keep running into this ERROR message: "move fewer modules or decrease the number of channels"
I'm trying to route a single line straight across from pin 8 to pin 7 (see picture) . Why can't it do this?
(6,430 Views)
I worked-around the problem by blowing away my workspace and starting from scratch. Very upset that I had to do that as it took a long time to re-create the workspace. If this is a known issue and there's a better solution, please let me know.
(6,427 Views)
I believe that you've encountered a bug in the router, where it marks a location as used, even if it isn't.
If you've already recreated the worksheet, then you should be okay.
We still cannot reproduce this bug on demand... it is a result of much editing, moving, copy, paste, and at some point, the problem occurs.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,387 Views)
Is there a method to eliminate all/anything located at a certain position?
(6,375 Views)
