DASYLab
Setpoint for Control
I would like to set a setpoint in DasyLab that changes with respect to time as specified by a ramp rate (RR).  For example:  the initial point is t0 = 0 second and the RR=6/minute.  The setpoint at t50 = 50 seconds will be 5.
Please help
(8,055 Views)
The best answer is the Sequence Generator in DASYLab Pro.
If you don't have Pro, then configure a Generator module to output the waveform. You'll need to tweak the settings to get it to work the way you want it.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,024 Views)
I used the generator module and got it work.
(8,014 Views)
