DASYLab
State machine
I've just had my first look at DASYlab and I have a task where I want to activate one digital output, measure analog input, if correct activate next output and so on... I'm thinking of using some kind of statemachine around a global variable, but can't figure out how to do it? If I've understod correctly the Global variable write-module just writes the input to the global variable. Any way to "if input active write x to global var"?
(8,391 Views)
Hello!
If you have hardware related issues when using our hardware I will gladly assist you troubleshooting it, but when it comes to programming issues about architecures and such you should contact measX:
http://www.measx.com/index.php?langset=en
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(8,367 Views)
You can do this simply using action module. Take a look!
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
(8,178 Views)
