DASYLab
Stopwatch in dasylab
I am new to Dasylab and I am trying to make a stop watch in dasylab that is uses an external input to start and stop (user controlled) and the timing data will be transferred to an excel spread sheet.
thank you in advance for any help.
(6,905 Views)
You could make a stop watch by using the counter module and use "Time for high level" as the Events to count.  Use the input for triggering.
You can use the file write module to save it as an ASCII file that will easily import to Excel.
Tom
InSyS Corp.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,900 Views)
Thank you very much Tom.
(6,896 Views)
