DASYLab
TCP/IP ICOM Setup (Problem with port)
When I set the interface port to anything other than 135, DASYLab tells me that the port cannot be opened.
In LabView this is no problem.
Any idea what I'm doing wrong?
Thanks for your help
Michael
(8,640 Views)
Michael,
To assist you, we need much more information. What port are you trying to open? What is the device? What does the IP address line look like ? when it works in LabVIEW, what are you doing (what command and configuration? )
The module offers only a generic TCP/IP client, but higher level protocols such as e.g. FTP or HTTP are not specifically supported.
-cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,640 Views)
