DASYLab
Toggle switches with if else
I am trying to toggle various switches based off of others and am wondering how I can go about this. For example, if switch A is on, B should toggle off. If I toggle B on, A should toggle off. Any help in doing this would be appreciated. Thanks.
(6,438 Views)
Thank you for an easy question.....
There's a mode in the Switch options that allows you to create a single switch with two channels, where only one will be on.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,436 Views)
