DASYLab
Triggered graph / chart
I would like to trigger a graph to show 1080 degrees worth of data. I have an X-Y graph (X: angle, Y: pressure) with the x-axis from 0-360 deg. That means I have three loops (0-360-720-1080 degees). When I plot, however, I get a bunch of loops. It looks like three sets of three loops overlaping each other. I have the "delete after" in the module settings set to 1. Here are some of the solutions I have tried to no avail:
I have used a circular buffer before the chart to release and reset every 1080 deg.
    -No change in functioning...
Reseting graph with the action module every 1080 degrees.
    -The graph is primarily empty, and when I try to freeze the graph for inspection it is deleted with the next reset function.
Update the display of the graph with an action module
    -doesnt seem to get me any progress.
Any other tips or ideas to triggering the x-ychart to work cyclically would be very helpful indeed! Many thanks in advance.
Robert
(6,279 Views)
Have you tried a larger "delete after" number?
It's resetting every one block.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,276 Views)
One block already contains too much data. I have triggered relays that allow measurements at every degree of rotation (via physical trigger wheel). For every rotation, I have 360 data points.
ASs I understand it, blocks are a group of samples so they are time-based. I need event-based data, so deleting by blocks will not yield a satisfying result. Is there a way to reset the graph via combi trigger?
(6,272 Views)
