DASYLab
Trouble collecting single points in Dasylab. Any help?
I have to see the worksheet. You can post a picture here... save the screenshot to a file and use the little Tree icon on the format bar.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 11 of 14
(4,098 Views)
Here it is. I know its a mess. But I am still learning.
Message 12 of 14
(4,095 Views)
Message 13 of 14
(4,093 Views)
Did you try this?
This is guaranteed to get around the error. Double click on the Switch module, click on Options, then activate "With Input".
Wire one of the other channels going into the relay into the Switch, to force it to use the TIMING ONLY from the channel.
-cj
Message 14 of 14
(4,088 Views)
