DASYLab
Using Dasylab V.8 I am monitoring temperatures. How do I have an audible alarm sound when something is out of my specified range?
I have done alot of research on Dasylabs forum and on National Instruments
discussion forums and I cannot find an answer. I am running
a distillation system for recycling antifreeze and I want to monitor temperatures and pressures/vacuum
on a pc. I have purchased Dasylab 8.0 and using it with an Omega instrunet 100
connected to a laptop. I am able to successfully display temps and pressures. I want to have one buzzer
to sound if any temperatures or pressures are out of my specified ranges. Example:
If a temperature on a pipeline rose above 310 degrees F, I would want an audible
alarm to sound so I can see what the problem is. I have played around with trigger
modules and some others but apparently I found that I have no idea as to what I am doing.
What are the proper modules to have and in what sequence do they need to be in?
Any help would be greatly appreciated. I can email you my .dsb file, or if I can
be so bold to ask you if you can send a sample of your .dsb file?
(7,851 Views)
Please see the answer to your question in the www.dasylab.net forum.
http://chat.advances.net:8080/~dasylabnet
--cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,845 Views)
