DASYLab
Vary TTL signal with slider or switch
I would like to vary the TTL phase 1 duration with a switch/toggle/relay/slider.  i am outputing a signal to PWM to control an ESC.  How can this be done in DASYlab
(5,688 Views)
Accepted by topic author donrafa7
You can create a Generator module, and select amplitude, frequency and duty cycle to modulate.
Then connect a Slider to that input to the Generator.
You'll need to work the settings of the Rectangular waveform to give it an offset so that it does 0-5, not +/-5.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,670 Views)
Attached is an example for DASYLab 2016 SP1.
(5,664 Views)
Thanks,  exactly what i needed
(5,660 Views)
I'm having trouble getting the speed to modulate,  the motor turns on and i can basically do 0 or 100.  I'm wondering if my timebases are off?  using an instrunet-423 at 5000hz.  Analog out  Can you take a look at my worksheet.  thanks
(5,636 Views)
Change the time base of the Slider to use the instrunet time base for output ...
Failing that, you'll have to check your instrunet output settings.
 Change the Slider Time base settingChange the Slider Time base setting
(5,634 Views)
that had a better result.  i can modulate somewhat.  The motor/esc seem to only be working when using 5000hz with a block size of 2.  Could my output frequency be too low?  also do you think i would get better results going to a digital output instead of analog?
(5,630 Views)
