DASYLab
Why cann't I get the right Signal in DASYLab from the PCI-Board?
Hi there,
I planed a new Voltage Task in the MAX. The Connecting Plan shows me the ports 68 and 34 for this Task.
68 is the Analog Input K00 and 34 is also an Analog Input K08. Is that right?
I thought 34 should be Ground or something else.
Anyway...
In DASYLab 9.0 I choosed the DAQmx Analog Input and a graphical visualisation.
In die Modul I choosed the right Voltage Task, but no Signal appeared in the visualisation.
What could be the Error? I also synchronised DASYLab with MAX.
Did I choose a wrong setting?
Please let me know your opinions...
Stefan
(7,341 Views)
Check the Task settings for acquisition mode, sampling rate and samples to read (block size). I usually suggest that you choose Continuous for DASYLab to work smoothly, with no gaps in the data.
If the Task tests correctly and shows you the correct signal, then the DASYLab NIDAQmx Analog Input should show the same information.
If you have further problems, please contact your DASYLab distributor, or go to www.dasylab.com to request support. You will want your worksheet, the NIDAQmx settings (use File/Export in NI MAX to save them), and the DASYLab Help/Report information.
Best Regards,
-cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,339 Views)
