DASYLab
Why does Daisylab only write 10 lines to a ascii file before starting a new file ?
I have an Data Shuttle Input Board connected to a combination of ovens, aluminum blocks and freezers. I can read and display this and then ned to write it to a ascii file.  The file only takes 10 lines of data before creating a new file in sequence.  How can I make it write to 1 file until I stop it? I am using the write to file module.
(8,935 Views)
Mike,
Open your File Write Module, click on the Multi-File settings, and change the number at the bottom from 10 to 0.
That will tell DASYLab to only write a file every time you start / stop.
Note that the Use Multi-File and Chain File Name Series should both be checked.
--cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,929 Views)
Thanks,  I'll try that.
Mike
(8,928 Views)
