DASYLab
Worksheet corrupting areas
I'm not sure how to explain this, but I am creating a new project and have been adding, deleting, and moving Modules in my Worksheet.  Now I have areas in my worksheet that act like there is something in that spot and will not allow a connection (wire) to run through the spot or allow a module to move to that spot.  Is there a way to clean up a worksheet?  At one time my project got locked up and would not respond and I had to have Windows shut it down.  This could have also caused the problem.  Any ideas on how to fix this?  I'm using DasyLab 13.0.
Message 1 of 10
(9,022 Views)
Stop. Close DASYLab.
Send me the worksheet. cj.butler@ni.com
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 10
(9,021 Views)
Hi Craig,
I have sometimes the same problem...
Try this:
-save your corruted worsheet in .DSA format
-open the .DSA worksheet and save it in .DSB format
The new .DSB worksheet should be "clean"... Smiley Happy
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
Message 3 of 10
(8,961 Views)
Thanks for the tip.  I can try that if it happens again.  CJ already fixed it for me this time.
Message 4 of 10
(8,958 Views)
Ok Craig, you're welcome!
And how CJ fixed this problem???
Frédéric Miqueau
Message 5 of 10
(8,949 Views)
Just to close this out.... in some cases, I can repair corrupted worksheets.
Contact me via email or private message with a copy of the worksheet.
Message 6 of 10
(8,769 Views)
Can anyone provide a solution to this issue? I attempted the (DSB to DSA to DSB solution and I still have the area corruption in my workspace.
Message 7 of 10
(3,112 Views)
I have been same problems with some worksheet. It would be nice if someone would have solution for that.
br Mika
Message 8 of 10
(3,094 Views)
Here is a solution to this issue.
To begin Close Dasylab and save a copy before continuing.
Go to the following location in your PC (location may differ slightly):
->  C:\Users\Public\Documents\DASYLab\14.0.1\eng
Open the DASYlab Configuration Setting using a text editor (notepad, etc.)
Under the text that reads: [General]
add a line and type: debug=1
Save and close.
Open Dasylab File with the corrupted workspace.
You will see placement outlines for the modules and traces visible.
Unused dots may be erased by
Left clicking with the SHIFT key pressed.
Once you have erased unused/inactive dots Save and close Dasylab
Return to the configuration setting and remove the added line "debug=1", save, and close.
Hope this helps.
Message 9 of 10
(3,030 Views)
Hello iglesiase,
I tried your solution but it did not worked
br Mika
Message 10 of 10
(2,981 Views)
