DASYLab
Write Module
I created a test set-up in DasyLab 6.0.  I need to be able to save the data to a spread sheet.  I would like to use the "Write" module, but it is greyed out in the drop down list.  How can I enable this module?  Is there a better/easier/other way to save the data to a spread sheet?
(7,435 Views)
The Write Data module is disabled in the Demo versions of the software. Click on the Help About, and look at the User Information tab to see if you are running a licensed version. If you are, then you should contact your reseller to determine the problem. If it is a demo, then you will need to purchase a license to activate all of the features.
Note, Version 6 is very old. We are currently shipping Version 9. See www.dasylab.com for details.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,433 Views)
