DASYLab
agilent 34970 with Dasylab
Hi
Does anyone Know Is it possible for me to use the Agilent 34972A with Dasylab 12. I have connected the device to max and installed the IVI drivers and everything seems to be connected ok (VIA LAN CABLE) However when i try to use the IviDmm+ module in Dasylab 12  i get the error.
IVI API Function IviDmm_ConfigureMeasurement return with error -1074135023.
Iam new to MAX and was wondering do you need to set up a channel list in max and if so how do i do this?
Thanyou
Brian
(5,910 Views)
