DASYLab
analyse DDF Files with a break
I have the problem, that I can't analyse the *.ddf Files, that were produced with a time break.
I used dasylab as a data logger. To reduce the data, the data stream was interrupted by a relais for a certain time.
Now I can see the data with a line writer, the picture jumps from lets say 16:00pm to 7:00am.
But the analysis of the data stops, when it reaches the 'time gap'.
How can I continue with the analysis?
Thanks for your efforts in advance
AndreasWi
(7,246 Views)
Hi Andreas,
In the settings for the Read Files Module, did you turn off the "Real Time Output" setting? It is on by default. That requires that the module obey the time settings in the file, including reproducing the lengthy gap of time.
If you turn it off, DASYLab will read the file as quickly as possible, and will skip over the gap quickly.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,243 Views)
