DASYLab
calculating velocity from an encoder using Dasylab
I trying to calculate velocity of an encoder using dasylab.  I want to use the following fomula: (Xn+1 - Xn)/(Tn+1  - Tn), where X is the sample and T is time.  I'm looking for a way to extract Xn and then Xn+1 continuously.
I am using Dasylab 10 pro with Iotech hardware
Any help would be great
Dan
(8,492 Views)
Hello Dan,
Since it looks like you're not using National Instruments hardware I would recommend that you contact Dasylab support directly.  If you are using National Instruments hardware please post back with the device model number.
Cheers,
Brooks
(8,472 Views)
Dan,
Are you using a counter/frequency card?
Coiuld I have the IOTech hardware you are using?
Tom
www.insyscorp.com
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(8,470 Views)
Tom, I am using the Ioech wavebook with the WBK17 counter input module. Thanks for the help Dan
(8,465 Views)
Use an Arithmetic module - One operante-Difference <=> It will give you the result of [ Sample(n+1)-Sample(n) ]
If you want to do it at your own sample rate put a Latch module before.
For time information use a TimeBase module (generate or extract from throw)
You can use also a PWM module to extract the frequency of your encoder
The problem if you do this is the sample rate of your application that must be higher (twice) the encoder output frequency max
The best is to use a counter input and extract directly the frequency.
Good luck!
H. Debruyne
(8,404 Views)
