DASYLab
can't install on DASYLab the NI DAQmx board 6221
I need some help to install the NI DAQmx PCI 6221 board. Even thought MAX has successefully test the board, DASYLAB don't recognized it. I don't know what I'm doing wrong! Please I need urgent help on this.
(9,622 Views)
Hi mneto.
"MAX has successefully test the board" Are you sure?
That means that your board installed successfully.
In fact I advice to reinstall the driver for Dasylab. http://www.dasylab.com/content/driver.php
You should note the drivers are different according to the version of Windows.
Best regards.
Message Edité par R_Duval le 11-08-2007 03:42 PM
Romain D.
National Instruments France
(9,614 Views)
What version of Dasylab ate you using? You need Version 9 (or higher 😉
) to work with DAQmx. Also, you need to create a task in MAX for your
measurement and then Dasylab can use this task.
Regards
Stephan
> Thanks
(9,601 Views)
I have a PXI/SCXI system thats about 5 years old with windows XP sp 2. I have installed and used Dasylab 8 on this system and used the NiDaq driver to access the hardware successfully. I'm now trying to install Dasylab 10.0.1 from a CD onto this system with no success so far. Do I need to upgrade this system in some way or upgrade WIndows to make it work with Dasylab 10? I have had no luck installing the program. JLW
(8,996 Views)
if you were successfully working with V8, then you should choose the NI-DAQ driver when you install V10. You have a choice of NI-DAQ or the newer NI-DAQmx.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,991 Views)
