DASYLab
change serial key
I had to replace an old computer that dasylab was running on (it got old, like me 😞  Anyway, I entered in the wrong serial key.  How can I change it without having to re-install everything?  This is Dasylab version 8
Thanx!
BoB
(7,285 Views)
Accepted by topic author rdepalma
Bob
Re-install DASYLab and select modify, it will show you the wrong key that at that point you will be able to enter the new one.
We are not getting old, we are just maturing 🙂
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(7,284 Views)
That did the trick thanx!!
(7,268 Views)
