DASYLab
chart left to right
I am trying to display a chart with slow data (1 point per sec thermcouple data) from left to right, over about 3 hours.  Does the chart recorder do only right to left?  I need to display the data against a reference curve.
(6,575 Views)
Look at the x-axis settings for the Chart Recorder.
Start at the Left is an option. Of course, once you roll over the right edge, it updates on the right.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,574 Views)
Is there any way to do this with the Diagram module?
(6,549 Views)
No, the Diagram module, because it's multi-modal, does not offer the same set of x-axis settings that the Chart Recorder does.
(6,537 Views)
