DASYLab
dasy lab interface with smart motor
Wondering if anyone has had any experience interfacing Dasylab with an Animatics smart motor . In my program I wish to have a data trigger module
send commands via. RS232 to a servo motor to make adjsutments based on my incoming data . I'm prety green at this so any help or advice in module selection and RS232 setup would be greatly appreciated.
 http://www.animatics.com/
Thanks Kent.
(6,129 Views)
What are you trying to do with it?
Commanding the Anymatics is very easy when you use theyr commands combined with DASYLab strings and variables.
You can use the RS232 monitor feature to test it.
I am working right now on a project that uses an SM23 and, thanks to their great support, is going easy.
I do have to say that it would help if you build some expresience in DASYLab first
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,127 Views)
