DASYLab
dasylab stops taking data at spike
Hello --
I am having a problem where Dasylab (Version 7) is freezing at a data spike.  THis has happened before when some of my instruments had bad wiring which caused a spike in the readings and Dasylab stopped taking data.  This time, I am discharging a high pressure tank quickly and taking a temperature reading that drops very quickly.  Dasylab stops updating a few seconds into the experiment.  At steady state (little to no temp change) I have run the data for over an hour with no stoppage.  It only occurs during the temp drop.
Any ideas?
Thanks!  Eric
(6,968 Views)
I would need to know more - what's your data acquisition device, and what does your worksheet do?
Are you running DASYLab V7.00.05? If now, download it from www.dasylab.com.
The best way to get support for this type of problem is to go to www.dasylab.com and fill out the support form.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,966 Views)
