DASYLab
error connecting to data source/target
hi everybody,
I try to use program but have a error follow image link.
Which module i will select for installation ?
Please send to me installation instruction for Dasylab ?
http://f1301.hizliresim.com/15/b/hu0tc.png
http://f1301.hizliresim.com/15/b/hu0tj.jpg
(6,624 Views)
That's not a driver issue. It's a Datasocket issue... can't connect to a DSTP or OPC source.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,613 Views)
ok how i can fix the problem ?
(6,609 Views)
Look at the DS Import module and determine what server it is trying to communicate with.
If that server is not available, then you get the error message.
This is not a DASYLab issue, per se, but an issue of your settings.
(6,605 Views)
