DASYLab
how to control timing of the signal generator?
Hello CJ,
I want to genetate a mixed signal which contains a 10 seconds Square wave, and then 10 seconds Sine wave. This signal then send out to the analog output.  Is there any simple way to do it? Thanks.
Alan
(6,631 Views)
In DASYLab Pro, I would advise you to use the Sequence Generator module. It allows great control of a generated waveform.
However, you don't, so, here's the alternate
Setup the Generator module for two channels, one for the Square Wave, one for the Sine Wave. Connect to the Control/Signal Switch module, configured for time. Setup up the time duration for each channel.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,630 Views)
