DASYLab
how to use dasylab
I'm Deepak Dudhankar from Mumbai ( India ).
I have a problem related to DASYLab.
I want to know if i can make use of the keyboard
to enter the numeric value of a variable,
And is there anyway in which i can use a keyboard
to enter alpha numeric ( Character ) data in the application developed using DASYLab ?
If possible please reply to me on dvd_6j@hotmail.com mail Id also.
Desperatly waiting for a prompt reply.
Thank you and warm regards
Deepak
Following are the queries, related to ongoing projects with V6.0
# Is Alpha-Numeric entries possible in Dasylab using keyboard.
# Can reports be generated ? If yes then limitations & ways to get it?
# Can Pci card faults be detected by Dasylab?
# Graph/Plot overlappi
ng features?
# Programmablity to change/edit sampling duration?
# Conversion from Dasylab data to excell file.
Pl explore the possiblities for above & kindly reply us back.
(8,633 Views)
There are several easy ways to update a DASYLab Global Variable. If this is your question, here is the answer:
1- Under Options/Define Global Variable, set up the variable with "Type in at Start of Experiment" checked. Then, every time the acquisition experiment starts, the user will be prompted for the value.
2- Use an Action module to "Enter Global Variable". This action will display a prompt to the user to enter the specified values. You can enter a list of variables to be updated. Any legal Event can be specified. Many users set up a Switch Module (One-Shot), where the user clicks the switch, and the rising-edge event causes the Action to pop up the prompt to enter the variable. You can also use Key Events to specify this action. (Optio
ns Menu)
3 - Use a Slider module as the user entry technique. Set up the slider to look like a data entry box (Slider Properties: turn off "with slider" to remove the actual slider display, leaving only the value entry field. The slider can then connect to a Variable Write module, or act as input to any other module.
I hope this helps.
Please see the www.ni.com Knowledge Base articles for your other questions.
Please see www.dasylab.net to download the Hands On Guide to DASYLab, for more assistance.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,633 Views)
