DASYLab
iotech personnaldaq 3005
I have a new PersonnalDAQ3005 I'm trying to run on Dasylab. It reads thermocouples fine on the IOTech software, but gives garbage when reading in Dasylab. It will however read differential voltage properly in Dasylab. I have already set Dasylab to read K-type sensors. Is there a "cold-junction" setting somewhere I can't find?
(7,495 Views)
Could you please let us know which version DASYLab and computer operating system?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(7,494 Views)
I'm running Dasylab 8 on a Dell laptop with XP.
I also have an identicle (but older) system which already works. When I swapped in the new DAQ, it stopped working. Is there a firmware upgrade? I've downloaded all the software upgrades I can find but still no success.
I tried using the support from the Dasylab site but it won't accept my serial # even though it is correct.
(7,491 Views)
Accepted by topic author Jambalaya
Have you contacted IOtech directly? They are much better equipped to assist you.
www.iotech.com
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,463 Views)
When measuring thermocouples with Dasylab, the DAQ has to be oversampled. In the device properties, set oversampling to x256. Everything works now.
(7,412 Views)
